Zum Hauptinhalt wechseln
Das 15" MacBook Pro, Modell A1989, kam im Juli 2018 auf den Markt. Es ist ausgestattet mit einem 15,4" LED hintergrundbeleuchtetem Display mit True Tone Technologie, TouchID und bis zu einem 6 Core i9 Prozessor.
203 Fragen Alle anzeigen
Why won't my MBP boot from the ext SSD
Had 2013 MBP that died.  Took out the SSD (with iFixit tools) and put it in an Other World Computing USB enclosure (Envoy).  Connects to new MBP 2018 via Other World Computing micro-b usb 3.0 cable with an Apple usb to usb-c adapter.  4 partitions (one aspf and three GUID Mac OS extended journaled) display on the screen and I retrieved the data that was not backed up so that all is well.  Running 10.13.5 and 6.
Then thought I would (for the fun of it) try to boot from the now external SSD.  Nope.  Fails.  See the circle with the line (ie no valid system). Have tried both command-R and system preferences.  Both offer it as boot option.  Have re-installed High Sierra.
Also Disk Utility says the drive is not solid state and is not bootable.
Other World Computing says I need a USB-C to USB Micro-B 3.0 and omit the Apple adapter so have ordered one but...
Why won't it boot?  And why does Disk Utility say it is not solid state and not bootable?
Is true, I retrieved my data so should give up, move on, but am now soaked in curiosity.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The new 2018 models hav a T2 chip in them unlike older MacBook Pro’s. The T2 chip offers a higher degree of security! As such somethings are a bit harder unless you tell it not to do something. Here is a good Apple T/N which reviews the different security levels About Secure Boot your system has.
Click on the External Boot ‘Allow Booting from External Media’ should resolve your issue.
War diese Antwort hilfreich?
Bewertung 1
7 Kommentare:
thank you but
is already set to allow ext boot and I have other ext drives that boot
also set to no security
will keep piddling with this
von
Was the drive protected in some way?
You may need to send the drive out to someone who can recovery it as it might have been damaged.
von
Thanks. The SSD drive shows on the desktop so I recovered all files. But now that I have it, I thought would try to boot from it. And cannot figure out how to make it boot reliably.
von
Try this hold the Option key when you reboot the system that will allow you to gain access to the startup Disk manager, then select your external that should do it.
von
Thanks but more than half the time it does not show up with Option boot, even if I connect the drive at the time the drive selection appears.
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Loren Engrav wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,035
