Zum Hauptinhalt wechseln
The Logitech Performance MX Mouse is a premiere mouse from Logitech with darkfield tracking technology and a free-spinning scroll wheel. Released in 2009. Model number: 910-001105.
15 Fragen Alle anzeigen
I got this mouse from goodwill I dont have a receiver
So, I found this mouse in a goodwill for 4 bucks.I noticed that it doesent have a reciver but a micro usb in the mouse. I figured that its a charging port for the battery. i wonder, does the micro usb serve as a “alternate mouse connection to the pc to make it work?”
Thanks!
(also the mouse works when i put a battery on it.)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The USB was designed to recharge the battery only.
But if you want to make it as an “alternate connection”, you will still need a receiver plugged into the PC. And you do not need the battery if you have it permanently on a USB cable.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Dude Thank you! it really helped!
von
Thanks, it helped you.
von
No it doesn't
It need the host Bluetooth conductor to function in any way
But luckily you can reprogramm it to work using any other receiver If you have any
Bewertung 0
2 Kommentare:
and another one
the mouse is using a unifying software
i did some reasearch and i found out that the logitech reciver is a unifying so it works in any logitech device ordered the receiver. waiting it for it to arrive.
von
great
that sound great
von
Antwort hinzufügen
Zander Castillon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 113
