Zum Hauptinhalt wechseln
Repair guides and support for computer monitors produced by Samsung.
87 Fragen Alle anzeigen
My monitor is double imaging pictures jumping with horizontal lines problem
Display problem with double images jumping and horizontal lines how to fix in my Samsung LCD panel LTM 190M2-L31
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
Yes, I tried all that but it is only on lcd penal problem (doubt).
von
Einen Kommentar hinzufügen
2 Antworten
Have you tried it on another computer or with a different cable (vga/dvi/hdmi)?
War diese Antwort hilfreich?
Bewertung 0
Ruby Sahu  since you already tried a different monitor and different cables, the issue will be inside your monitor. It is possible that this is caused by a bad video scaler on your board. You will have to disassemble it and take a look at the board for obvious damage like domed or leaking capacitors. Post some images of the board with yuor question so that we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that. Also, post some pictures of what your dispaly shows hen you start it up. It is possible that this is caused by a bad LCD driver board,. Replacement panels are available but a bit expensive. Let us know what exact model your monitor is.
Bewertung 0
Antwort hinzufügen
Ruby Sahu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 447
