Headlights and fogs not woking
1985 Mercedes 300 cd turbo
head and fog lights do not turn on
have replaced all fuses, checked ground on passenger headlight corner
passing light lever on turn signal will make headlights work therefor its not the bulbs
rear defrost out
cruise control out
tachometer works, speedometer works, turn signals work , rear lights work, hazard lights work.
no loose wires apparent
help please
Ist dies eine gute Frage?
2 Kommentare
I went to my fuse panel last night and checked for continuity which was present, will check the voltages tonight. I did however put a brand new light switch in a few days ago and got nothing so am assuming I do not have a bad switch unless a terminal was connected improperly by someone diddling with it prior to my work on it
von zenon duda
it was a loose connection under the fuse panel and to the left of the brake pedal beneath the kick panel drivers side
von zenon duda
