Zum Hauptinhalt wechseln
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
power loss when accelerating
I need help I have a Ford Mustang GT 2004 and the problem I get is when I step on the car does not react aggressively and begins to pull speeches but at 2000 revolutions takes off is a period of time in which the engine dies. I already change coiles, new spark plugs, filter zagolina, service to the injectors and remains the same as any recommendation would be quite grateful
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Check your compression . Any drop in compression will hurt the performance. Is you car losing coolant? Is it casting any codes ? If so what ? Was there any misfires before you changed out the plugs and coils . If so you may be dealing with back-pressure from the catalytic converter. Raw fuel in the converter can cause it to plug and a plugged converter kills power . Also do you have an aftermarket tune on the car . Change out the air filter as well so it can breath Just a few things to look at . Hope this helps
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
it acts like tractioin control it takes off better if I turn it off
von
So what’s the problem? What exactly do I need to fix if I changed my spark plugs and nothing changed oil changed. After market pipes caused my Cadillac was clogged
von
Antwort hinzufügen
José saracho wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 2,954
