Zum Hauptinhalt wechseln
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
58 Fragen Alle anzeigen
Physically hack-proofing 9.7" and mini iPads
Many organisations with security concerns are sourcing modified wifi-only iPads which can be utilised in high security environments. This requires removing the cameras and microphone. What would be involved in this mod on both mini 4 and ipad 6 models? How long would it take and what tools would be required?
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
MacBook Akku Fix Kits
Ab $69.99
Buy Now
Ab $69.99
Buy Now
2 Antworten
Gewählte Lösung
On the iPad mini 4, just open it up :>). Everything you want to remove is at the top end of the device, the two cameras and the two microphones (just look for the pin holes in the top right corner to locate them). The same would apply to the iPad 6 although the internals are slightly different. Check out the various guides here.
War diese Antwort hilfreich?
Punktzahl 3
You can set restrictions to disable camera and microphone - but users can re-enable by resetting all settings.
To make them permanently disabled, you need to physically remove them per Minho’s comment.
Punktzahl 1
Antwort hinzufügen
Mark Taylor wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 30
