Why a certain website is freezing on loading the page?
I check if the problem is present on a different computer , and from the same router machine. And there is no problem. So the router is not blocked. It must be an IP related blockage. Thank you. Also... I suspected maybe is a special dedicated virus for blocking a website on a specific IP? I scanned my computer with an AV (antivirus) Malwarebytes and nothing is found.
Ist dies eine gute Frage?
is it only one website? or do a bunch of websites not work? if it's only one what is the specific website?
von Aiden Baker
hi, its a NSFW type of website and there are a couple of them having the same symptom (loading partially or not at all).
von teodoric8
Are you using any ad blockers on your browser or anti-virus on computer? They may interfere with the websites and cause issues like that.
von Ben
I found the problem - It was from DNS.
Now, I have further problem. In DNS setting , there are 2 options. If I set the first option : "obtain DNS server address automatically", after some time (not immediately after I close and reopen it) the option switch to 172.98.193.42 in the other option : "use the following dns server addresses". I read that the last number over 30 it means security for childrens ,etc.
I have click on "Advanced" button in the same window with DNS options, I go to DNS tab, and there I could see and delete the adress. When I delete it from there, in the firts DNS options, automatically switched to "obtain DNS server address automatically".
----------->part1
von teodoric8
----------->part2
The problem is that, again, after some time (not immediately after I close and reopen all these settings) the option switch to 172.98.193.42 in the other option : "use the following dns server addresses". I don't know what is triggering the option to switch back. My impression/guess is that is commuted when I access these types of websites. I didn't made the test yet to be certain of the cause.
Please advice, where could be the main trigger?
Thank you!
von teodoric8
1 weiteren Kommentar anzeigen
