Zum Hauptinhalt wechseln
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
196 Fragen Alle anzeigen
My nintendo 2ds xl wont turn on?
It wont turn on. I have it plugged in. The orange charge light is on. But whether it is plugged in or not, when i push the power button, the blue light comes on for about five to ten seconds and then shuts off. No screen activity. And you can hear it shut off. It makes an audio click off type sound. Whats the diagnoses? I had it in my back pack. Too much pressure?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 7
2 Kommentare
i as well like ass
von
love you kyle
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hey, Kyle. This can be caused by a couple different things. The first place to check is the battery. Remove the battery and inspect the three gold terminals for signs of corrosion. Then inspect the corresponding terminals on the board. clean these carefully and reinstall the battery.
If that doesn’t fix the problem, you’ll need to open your device further and check the two ribbon cables on the board (or any of the other 6). Based on what you said about the popping noise and the pressure of your backpack I would say this is most likely your problem. You need to make sure the two gold colored ribbon cables aren’t loose or damaged and that the pins on the board are also not damaged. Be gentle with the cables. If the cables are properly seated your screen is likely damaged and will need to be replaced. Let me know how it goes. Hope this helped and good luck!
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
I had the same issue, and I'm aware of how the 2ds xl works. So my instinct was that I had a bad cable or display, but then I heard you mention the battery. When I took out the battery it looked just fine, so I thought it couldn't be the battery. I reinstalled the battery and then the 2ds xl turned on just fine.
So in short, it may be possible that you have the same issue that I had. Try taking out and plugging the battery into the 2ds xl
von
We have an issue where it knowingly got wet, but still charges, but won’t turn on. How do we fix it?
Bewertung 0
2 Kommentare:
My 2DS XL is brand new and now the screen won't turn on the origin light and red and blue lights come on but not the screen. What can I do?
von
I was having This same problem and then i just smacked the back of it like 15 times and it works now. https://c.tenor.com/p6od-lJcYHwAAAAd/the...
von
my console was working but touch was not working
so i change the touch and now it charge but not turn on ? ?
i checked all cables no sign of life
Bewertung 0
Antwort hinzufügen
Kyle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 63
Letzte 30 Tage: 279
Insgesamt: 23,009
