Zum Hauptinhalt wechseln
This multimedia-geared dv6 comes with a 15.6-inch display, a built-in stereo, and weighs just under 7lbs. It is simple to disassemble- only a small screwdriver and a paper clip are required.
Hp pavilion m6 Caps lock blinking once after 3 secs no boot
Hi
2 days ago My hp pavilion m6 turned off suddenly for 2 3 times without warning. But it was able to turn on.
But today after a sudden turn off it is not turning on. Just gives a black screen, no fan etc. And Capslock keep on blinking once after 2 3 secs. And sometime it turns off after only one caps lock blink.
After sudden key combinations like pressing all arrows keys or alt+del+ctrl and power on. I am able to make caplock blink but on ac adapter capslock blink only once and laptop turns off. On ac adapter, there is no continuous capslock blinking just one caps lock blink and it turns off.
please help me.
Please help me here.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
Hi Affaq
Suggest you to access the RAM and if there are multiple RAM modules installed, take out out and test each at a time.
HP Pavilion dv6-2158nr RAM Replacement
von
Einen Kommentar hinzufügen
1 Antwort
It is very possible that there is a short in the motherboard.
Things to try:
Reseat the RAM (memory)
Remove battery and hold the power button for 10 seconds. Plug the battery back in and then plug in the charger. Try again to turn on.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Affaq Aslam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 3,881
