Zum Hauptinhalt wechseln
Das Galaxy S6 ist das neue Flagschiff der Galaxy-Linie. Es wurde im März 2015 angekündigt, Verkaufsstart war am 10. April. Die Version mit dem gewölbten Bildschirm ist unter Galaxy S6 Edge bekannt.
486 Fragen Alle anzeigen
An error has occurred while updating the device software...
Alright so a while ago my phone got stuck in a bootloop, and I finally decided to fix it yesterday. However, I was an idiot and accidentally disconnected the cable while flashing on a new OS, and now my screen just says “An error has occurred while updating the device software. Use the Emergency Recovery function in the Smart Switch PC software” whenever I try to flash anything on. I tried smart switch, but it’s an s6 and it’s unsupported now. I tried kies and it just kept “Connecting” for over an hour so I’ve dropped that one too.
TL;DR, what program will let me restore my galaxy s6? Or what version of smart switch has the s6 supported.
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
Try using an older version of SmartSwitch and see if that works on your phone.
The S6 was released in Apr. 2015 so you’d think that the SmartSwitch Ver 4.0.116011_3 released in Jan. 16 would work.
Just a thought.
War diese Antwort hilfreich?
Bewertung 4
I’m using the samsung J1 core and there was an error just like the one you are describing. So I downloaded the latest smart switch software but doesn’t seem to detect my phone. So I downloaded a previous version of smart switch software. It detected my device but then it wasn’t able to fix the error. A new error message pops up saying it doesn’t support my device.
Now i’m trying to download the firmware and install it on my phone using Odin software. The firmware file size is around 772 MB.
You can check out the steps at Hocview
Bewertung 0
Antwort hinzufügen
Mark Zuckerberg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 8,751
