Zum Hauptinhalt wechseln
Veröffentlicht am 21. September 2018. Modelle A1920, A2097, A2098, A2100. Erhältlich als GSM oder CDMA / eSIM oder dual-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen "iPhone 10s.")
398 Fragen Alle anzeigen
Is the iPhone X Display compatible with the iPhone XS?
I figured out this is a big question for the repair community, no one yet answered.
Is the iPhone X display compatible with the iPhone XS? On paper they look the same. They even have the same number of pins in both connectors. But there is still no confirmation of anyone who has tried it.
I hope someone has an answer for this.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
5 Kommentare
Gee! The phone was just released. No one is trying shuffle games with the parts yet. Even still it will likely be a good year before you could even get your hands on a display.
So far Apple has not made displays interchangeable on any of its phones so I doubt this is even possible.
von
5s and SE are the same!
von
Yeah I just literally swapped a 8 screen onto a 7 logic board works
von
iphone x and xs are the same it works
von
I just exchanged 1 but the earpiece boards and are not aligned together
von
Einen Kommentar hinzufügen
22 Antworten
Gewählte Lösung
Yes i try to iphone x dispay install to iphone Xs working perfect. I this colour resolutions only different
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
its just the clips that hold the screen in they are in different locations
von
The x screen will not work perfectly with the xs phone. The xs screen will work 100% with the x phone. They are backwards compatible but not forward compatible. The top right clip on the screen and the bottom two clips on the side are slightly misaligned but could be trimmed off.
von
Would you happen to have a pic of what your talking about sorry I just do better seeing it then reading it
von
Hilfreichste Antwort
Actually iPhone X and XS’s batteries and screens are compatible with each other. See 3:00 of this iPhone XS Teardown
Bewertung 6
3 Kommentare:
The screen frame is not compatible
von
Yeah, iPhone X screen can not be installed to iPhone XS, Frame not compatible.
von
You could always switch try to switch your shell
von
Well, the IFIXIT team just took apart the Xs Max and they made a comment the face facing camera is not mounted on the display like the older models so I guess that answers the question No!
See for your self here: iPhone XS Max Teardown LIVE with BEER!
Bewertung 2
2 Kommentare:
Back camera iphone x can use on iphone xs??
von
Uh the front camera module isn’t attached to the X display though? I’ve got one open right now, last iphone I know of that done that was the 8
von
I can confirm it works fine, Just a difference in the metal clips down either side of the screen frame, So no good for replacement, But handy for data retrieval etc
Bewertung 2
Just to give my experience, today i grab a X screen as customer told me is a X. I test lcd everything works, i go to close it and it won’t fit due snaps. After verify the iPhone is a XS dam, custumer agree to cut all snaps and glue it. It work flawless so far. So X and XS are compatible the only problem is the metal snaps that won’t fit, cut will always solve but you risk in damage it
Bewertung 2
3 Kommentare:
Just change the frame from the old broken screen onto the new screen. Worked for me.
von
Only one clip on top speaker left and side clips need to trim a bit and all ok 100%
von
Well explained 💯
von
No, The connector to the motherboard is slightly different, therefore cannot be plugged in.
Bewertung 1
4 Kommentare:
This is wrong. Tested on A1920, the regular X screen connectors fit, screen works and even touch and Force Touch work. Just one screw and the snaps are placed differently, which is the reason it *won't fit*. By the way, the als programmers work too :)
von
hello Ben
the display and all electronic components are the same, just frame are different
br
David Peña
von
Could you just switch the rear shell so the other screen would work
von
This is wrong, the connectors are identical, They even have the same part number on the connector (3d)
von
They fit almost exactly with each other but the frames of the LCD is different which doesn’t work
Bewertung 1
I can confirm, it is working perfectly and yes the frame is different so I removed the frame from the old broken XS and fitted it onto the new X screen and now it’s a perfect XS fit.
Bewertung 1
3 Kommentare:
how did you do that? remove the frame, please explain, thanks
von
Be careful...I thought mine was ok (not knowing that I was sent the wrong screen until a few days ago when my iphone X CAUGHT ON FIRE as my husband was holding it in his hands. It melted half the phone. We took it apart to try and save the information on the motherboard and thats when I found out that an XS screen was put on my X model.
von
@barbiebeth not likely to be the display at fault there whatsoever, unless it was a cheap aftermarket LCD panel. To cause an explosion of the level you explained, it’d have to be a battery related issue (hence how I said it could also be caused by a fake aftermarket LCD instead of a proper OLED panel; they draw more voltage)
von
the Xs screen will turn on and work with the X but it won’t fit in properly and the proxy wont sit flat on the screen.
Bewertung 1
Just tried it. Won’t work, prox is different, at start, the chip set for LCD and Digi is also different
Bewertung 0
I’m almost 90% positive that they are same with only difference in frame, like it was on 7 to 8 and 7+ to 8+ screens
like it was to 4 and 4s screens
i just have no xs to confirm it myself
Bewertung 0
1 Kommentar:
@ jambulat mikadze Ever tested a 8 with a 7 display because you may not have had an 8 display available? And couldn’t figure out why Touch ID never worked on the ones you tested that way?
von
Is iphone x motherboad can be fitted in iphone xs ?
Helpp ….
Bewertung 0
When have u ever known apple parts to be the same… even on the 4 and 4s they changed the frame, so even if the x and xs has the same screen it will still have a different frame
Bewertung 0
Not Compatible. Both are different screens.
Bewertung 0
iPhone X
5.8-inch; 2,436x1,125 pixels
iPhone XS
5.8-inch Super Retina OLED; 2,436x1,125 pixels
Bewertung 0
1 Kommentar:
Just because something has the same physical size doesnt mean its compatible.
Samsung and Apple screens could be the same dimensions but wont be compatible with eachother.
von
I have tried it and I don’t know what’s going on but 3 different x logic boards same brand new xs display. Same flashing white apple logo. I’m not experienced, certified or qualified in any way. But I’ve worked on a lot of apple phones. For personal use. A lot. And I can’t even get the device to restore or update. It does into recovery mode just fine. That’s all I know.
Bewertung 0
1 Kommentar:
change the face id...has to be the same one that came on the original screen
von
No, and even if it will fit, that will make an motherboard issues on a longterm usage
Bewertung 0
Bewertung 0
I put an iPhone X screen on XS its compatible plug wise but it does not allow the frame to work. XS has smaller hinges that clip into the side of the phone and also right top hinge is misaligned by a little. Of course apple would only make those changes : )
Bewertung 0
hello there,
So a customer of mine brought me a iPhone x so he said not realizing its a xs so i ordered x glass by the way i have to replace battery also since its been wash in the washing machine i was abe to fix the charging port since it wasn’t charging after battery replacement… so to answer your question well like i said i ordered x glass and also x battery put them on and charged it and it work unfortunately having a network error and need to be updated but just to be on the safe side i order again a glass for xs just incase …but its working (:
Bewertung 0
I bought a broken phone was told it’s iPhone X but had trouble getting it to align into frame then noticed the top clips were in slight different locations all plugs same but it’s actually xs the screen works fine too speaker it same location just rage frame clips are different I’m using it with tape on it till I get new xs screen so yes compatible just need tome tape lol
Bewertung 0
1 Kommentar:
I ordered an X replacement screen and noticed the one that arrived has tabs. The phone I have (it is an X not XS) doe nor have ANY tabs on the old screen. So I’m only assuming I was sent an XS replacement?
von
yes it worked for me lol. some guy came with an iPhone x saying it was an iPhone xs and the screen worked lol but the only reason I needed to know that the phone was a X and not a XS was because of the amount of screws on phone speaker.
Bewertung 0
Antwort hinzufügen
javierriveraurruela wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 140
Letzte 30 Tage: 556
Insgesamt: 52,644
