Zum Hauptinhalt wechseln
Model A1347 mit 2.4 GHz oder 2.66 GHz Intel Core 2 Duo CPU
just tone and no boot after Mac mini mid 2010 16GB upgrade
After installing the upgrade the mac is just generating a tone every 4-5 second and does not boot. I saw on the guide page that at least 2 other users had the same problem. Anybody has an idea of what to do?
Thanks
Frederic
Update (09/25/2018)
I am running high sierra on that mac but, with only 2GB, it is struggling, hence the temptative upgrade…
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Do you still have the original RAM (in working order)? If so, try plugging the original RAM in and see if this behavior continues.
A beep every 5 seconds typically means bad, incorrect or no RAM.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
that is the first thing I tried. when I put back the original ram, it boots without problem. then I put back the 16GB and it went back to beeping. If it means no ram or bad ram could that be that I received bad RAM?
von
@freblewski Try @danj 's solution, then if that is a no-go you have probably received bad RAM. Comment below mentioning me if Dan's solution does not work.
von
In order to run 16 GB you’ll need to be running OS-X Lion 10.7.5 or higher and make sure you’ve updated with the latest EFI firmware. The highest this system will run is macOS High Sierra 10.13.6
If you’ve not updated to El Capitan OS-X 10.11.x or newer you’ll either need to do that first or manually install the newer EFI firmware from here: About EFI and SMC firmware updates for Intel-based Mac computers
Bewertung 0
Antwort hinzufügen
frederic reblewski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 26
Insgesamt: 1,024
