Zum Hauptinhalt wechseln
1,86 GHz oder 2,13GHz Prozessor, 128 GB oder 256 GB Flashspeicher
How to remove a stripped pentalobe screw
Hi.
When doing the bottom case assembly (with the pentalobe screwdriver from ifixit), one of the pentalobe screws got stuck and a few attempts to turn it made the head stripped. I have a replacement screw, but I'm unable to take this one out.
I've seen numerous posts around here regarding this matter, but none of them were concerning the pentalobe screws.
Any suggestions on removing the screw?
Thank you.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 8
11 Kommentare
Sorry for not mentioning that the laptop is on warranty until November 2011, so I wouldn't like to mess it up by Drilling or dremeling.
Using a bigger torx screwdriver didn't help, unfortunately.
von
Don't go bigger...;-) use lemerise idea of modifying a flat tip screwdriver.
von
the screw cap is so "screwed" that the screwdriver goes round and can't "catch" the screw to make it turn.
I tried to stick the screwdriver to the screw using super instant glue - didn't work.
My next step will be finding a flat screwdriver this small to fit into the screw cap.
If I turn to using a dremel the rotating blade should really be miniature..
von
use your Dremel to modify your screwdriver. The jewelers screwdrivers a re great for that start with a flat tip a little bigger than what you have left from the screw head and modify it accordingly. If you do not have a Dremel any kind of small grinder will work
von
thaks for the advice, oldturkey03, but can you please show a couple of images of the tools you are speaking about the Dremel and the grinder? that'd be really helpful.
von
6 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Drill it out (very carefully). Once the head is removed you can easily turn the remains of the screw with needle nosed pliers. Take care to clean up any chips from the drilling, use compressed air and/or a magnet.
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
Thanks, but is drilling really the only way?
von
Of course not - see lemerises answer.
von
Hilfreichste Antwort
When I have this problem with a torx screw I use a small flat screwdriver that can enter between two notches and apply a little force to unscrew the $%#@$%? screw. Maybe you can try this trick. If your MBA is no more covered by the Apple warranty you can also use a Dremel with a small rotating blade to make a notch and then use a flat screwdriver to take off the screw.
http://www.dremel.com/en-us/Tools/Pages/...
Bewertung 7
2 Kommentare:
+ love the Dremel ;-)
von
Man.... thank you for the Dremel trick.. that made my day! I might reuse that one in many other occasions! THANKS for sharing!!!
von
I had this problem with a Torx 5 screw inside a MacBook Air, tried every trick in the book to get the !@#$ thing out, to no avail. Here's what ended up working for me:
I very carefully sanded the surface of the stripped screw with 320 grit sandpaper, making extra sure I wasn't contacting any surrounding components. Then I cleaned the screw head off and applied some petroleum based soldering flux onto the sanded screw head. I then got my soldering iron up to temperature and melted some solder onto the head of the screw. I added solder until it filled the stripped out torx hole and formed a small dome on top of the screw. While the solder was still melted, I pressed a flathead screwdriver into the solder and kept it still until the solder cooled. When I removed the screwdriver tip, there was a perfect flathead impression in the solder. Then I just used the flathead screwdriver to remove the screw normally...it came right out! I suggest anyone who has the parts/supplies to do this, definitely give it a try.
Bewertung 5
I read somewhere that Apple uses Loctite on their pentalobe screws. I researched what would melt Loctite and the answer was HEAT. So I carefully heated the pentalobe screws with the nozzle of a glue gun (without the glue, of course), and after a couple of minutes, we could screw the screws right out.
This answer is for unscrewing pentalobe screws in general. For the guy with the screw with the stripped head, heat the screw and then use a pentalobe screwdriver (TS4 1.2mm or 1.4 mm) or a #00 or #000 phillips screwdriver to remove it.
Hope this helps.
Bewertung 5
2 Kommentare:
5 years later, this tip helped me get a stubborn MBA case screw out- thanks! I thought I was stuck as I’m pretty sure I had stripped the screw already, but after a few seconds from a heat gun I was able to get it out.
I think Loctite could definitely be a factor, another might be that the heat expands the screw and/or casing a bit and causes it to loosen up a bit.
von
@madmaxmedia
Definitely Loctite.
von
We have just recently added these screw extractors to our store. They would fit that screw size for the MBA and might be able to take out the screw. Screw extractors, in general, don't always work depending on how stripped the head is, but it's an alternative to trying to drill it out.
Bewertung 2
Lowe's has removal tools, basically it's a coarse, reverse threaded carbon steel bit that is designed so that as you twist the bit counterclockwise (out) it digs into the head of the screw. If you can find one online that's small enough it could do the trick. http://www.amazon.com/Made-USA-53700-Spi....
Bewertung 1
Hi guys,
I just had this problem on the rear case of my MacBook Pro.
4 of the 10 were rounded.
I managed to get them out by filling the tip of the Pentalobe Screwdriver.
The cheap one I used has a tapered tip, so if you file it, it gets slightly bigger/wider.
Once I feel it has a bite again on the screw, I used quite a bit of downforce to make sure it did not slip.
I got them all in the end, the screwdriver needed more filling for the worst of them.
I hope this helps :)
Bewertung 1
Antwort hinzufügen
sergesavranchuk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 44
Letzte 30 Tage: 183
Insgesamt: 80,025
