Zum Hauptinhalt wechseln
Das Lenovo IdeaPad 300-17ISK ist ein 17-Zoll-Laptop, der im Oktober 2016 auf den Markt kam. Die Modellnummer lautet 80QH008MUS.
My device won't power on
My model is actually the ideapad 320-15abr. My issue is it won’t power on unless I do the reset procedure by removing battery holding down power. I have to do this every time and only works some of the time. Last time I left it on and it was completely off two days later and will not power on. All diagnostic tests came back good.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
HI:
Going out on a limb here but I think your power supply is hooped.
Or failing or faulty. This could include the plug at the end or even the power plug at the laptop may be broken or faulty inside. If you can borrow another supply or even take the units to a friendly computer shop for a quick check.
This trouble could go all the way to your motherboard.
Have worked on hundreds of laptops but this is a strange one.
Good luck
AB
War diese Antwort hilfreich?
Bewertung 0
If your laptop is showing no signs of life and refuses to turn on, use this Lenovo IdeaPad U530 Touch Does Not Turn On problem page for possible causes and solutions.
Bewertung 0
Antwort hinzufügen
chrisellis87 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 525
