Zum Hauptinhalt wechseln
The HP Pavilion dv6500 is an affordable multimedia notebook with a 15.4" screen , a stylish case, and a security fingerprint scanner.
Working charger won't power or charge laptop.
Have a DV6500 HP laptop with good battery and charger. Suddenly it will not charge or power up when charger is plugged in. When I charge the battery on another laptop and put in the defective one, the laptop will run fine. I have replaced the charger board but no success.
Any Ideas?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Thanks for the answer, but unfortunately that did not solve the issue. I’m thinking it may be a hardware issue in that it was charging the battery and then suddenly stopped. The charger has tested good, the battery is good and I have changed the charger board out. The computer works fine with a battery, unfortunately I cannot charge the battery or power the laptop with the charger.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
HI:
I would say you have a corrupted battery driver, did you know the battery needs a driver to charge.
Got to control panel and find device manager, Battery, uninstall the drivers and re boot with charger plugged in . Windows will be looking for a driver API, you may have to go to the internet to get the driver, install it and reset again.
I hope I understand your explanation and this works.
Good luck.
Alton
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
csand wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 492
