Zum Hauptinhalt wechseln
Device repair information and troubleshooting for the HP Pavilion g6 laptop.
55 Fragen Alle anzeigen
Computers starts but the screen doesn't turn on?
Some call this issue “Screen of death”.
So I used to open my laptop and do work on it. Suddenly, my laptop stopped turning on. The fans, lights, and sound works!
BUT the screen doesn’t work. I even plugged in 3 monitors to try to see if the laptop screen’s is broken and not the system. But the same thing happened. The laptop turns on but the screen/monitors doesn’t work.
Any solution?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The problem would be the graphics adapter built into the mother board. You can look in the repair manuals on iFixit to see if a part number for the mother board is listed and how to change it. You may be able to find a replacement mother board on the internet, search by part number and make sure you are getting is what you order. You should also do a cost analysis to decide if replacing the mother board is cheaper than buying another laptop, if the cost of repair is more than 50% of the cost to replace then go for replacement. The hard drive should still be intact, it can be mounted in an external drive case and connected via USB to copy the data.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Ameer Al-Turaihi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 72
