Zum Hauptinhalt wechseln
Das Huawei P8 Lite (Modell: ALE-L21) angekündigt im April 2015, verbindet Schönheit mit Schlichtheit. Seine professionellen Kameras ermöglichen es dir, selbst in der düstersten Umgebung natürliche und scharfe Fotos zu machen. Der Beauty Modus hebt die schönsten Seiten des Eigentümers in jedem Selfie hervor.
110 Fragen Alle anzeigen
Why my phone has weak gsm signal?
I followed the guide to change display with frame. Now I notice that my phone has problems to receive gsm signal, above all when it’s indoor. Looking the old frame, I see that there are some little pieces of conductive tapes in precise points
Maybe thes points are useful to connect motherboard to ground?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
My mobile huawei p8lite 4g not work only 2g work problem
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Static electricity can cause bad signals with antenna’s so maybe try to buy some conductive tapes and placing them on these points to get that charge out of there. It should be worth the try
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
thanks for answer.
i tried to put some conductive pads, but signal is still weak.
If I stay indoor far from window, phone can’t transfer datas by 3g/4g even if signal indicator is good. I see that indoor phone is not able to work by 4g.
If I stay outdoor, phone works perfectly (also by 4g).
It seems that antenna doesn’t have enough power.
I noticed also that the weight of 10kg falled nera sim holder on the display where maybe there is gsm module of mainboard.
von
Antwort hinzufügen
Massimo Martucci wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,123
