No on light after boot up chime
1. The on light at the front goes off after the start up chime.
2. The computer does not sleep when the lid is closed, however it will via Energy Saver or via the keyboard shortcut.
3. The battery is only recognized for 48 seconds after a cold start up. At this time the System Profiler say that the battery is charging, the Cycle Count is 0, and the Condition is good. The battery and charger are both new.
When I first got this used MacBook Core Duo the computer would start the sleep mode (front light pulsating) directly after the start up chime. The previous owner replaced the LCD because the screen was always black or very dark. The computer would just go back to sleep as soon awaken. However, this issue was resolved when the battery connecter /sleep switch was removed and cleaned.
My next step is to remove and clean the entire logic board. I was just wondering if anyone has any similar issue or may have any input, suggestions or ideas at all. Anything would be highly appreciated.
Ist dies eine gute Frage?
1 Kommentar
Well I just finished cleaning all of the 20 pin connectors and sockets in the Battery/sleep switch and now they are all giving me very good connection reading via a continuity tester. I am now also getting good connections from the Magsafe receptacle at all of the 6 battery connectors. However the results is the same. But when I test the Charge control pin (middle contact on the Magsafe) I get a blink or a false connection like a ground. Is this normal? Should this be a straight connection? Is the power in the center pin reduced? Is this what detects the battery? Has anyone here tested this connection?
von Joe Gordon
