Zum Hauptinhalt wechseln
A1708/EMC 3164 — Veröffentlicht im Juni 2017, behält dieses MacBook Pro Einsteigermodell die traditionelle Funktionstasten bei (im Gegensatz zur OLED Touch Bar).
563 Fragen Alle anzeigen
Replace Logic Board to Upgrade Specs
Hey guys, I’m aware that since my cpu and memory is soldered to the logic board, that I personally can’t swap out memory sticks to upgrade my ram for example. However, is it possible to purchase a new logic board with 16GB of ram (I currently have 8GB ram) instead of buying a whole new macbook pro? Thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Problem might be finding the logic board in the market since it’s a relatively new model, but the replacement can be done, besides specs shape is the same. Unfortunately there seems to be not yet a guide on IFixit to help you. Pay special attention to the smaller connectors of loudspeakers, keyboard and relevant backlight and make sure you have a spudger to help you in the job. Watching guides of previous models will help you figure out how to correctly remove parts. If you live in an area with dry weather conditions you may want to ground yourself to avoid triggering static charges.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Yes, a ESD mat and strap is a must in dry climates or in the winter!
You still might find buying a newer system will end up being cheaper after selling yours.
von
Antwort hinzufügen
Lachie Woodards wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 181
