Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost, bis zu 512 MB DDR5 Video RAM
1637 Fragen Alle anzeigen
no LCD or backlight. tested two LCD panels, external monitor is good
i recently decided to make another pass at this 2012 MacBook pro which has been sitting in my drawer for some time. I have no history on the unit, it arrived as part of a lot of non-functioning MacBooks. no tripped moisture indicators, and the innards didn’t appear tampered with.
said MacBook will chime and boot fine, but never outputs display to the internal LCD. it’s obvious that the backlight isn’t illuminating, and the flashlight test yields no activity on the LCD itself. needless to say, uncountable SMC and NVRAM resets have occurred, as well as reinstalls of macOS. i have tested this on two separate LCD panels, the second is “known good” from a working machine. for what it’s worth, this test was accomplished by transferring the MLB to another complete MacBook, rather than simply connecting another display in place.
i have my normal routine for no-backlight-having MacBooks, but the no LCD is throwing me for a loop.
advice (other than genius bar, replace logic board, etc) is most welcome!
i have tested all of these points, none show 3v3:
following the board view, i also have no 3.3v at R1984, but i don’t know how to follow the trace to what i’m assuming is the other side of the board?
there appears to be some tomfoolery at the battery status connector (which has an SMC function as well)
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
hmm, this does look like a logic board issue to me, sad to say. I’ll let the more experienced people do the talking though.
von
yes i have surmised that it's a logic board issue. my hope is a short list of common points to check!
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@reverendalc
check the display connector. Check for bend broken or corroded pins. Post some images of your logic board with your question. That way we can see what you see. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that.
Measure the connector and see if you have the voltages required to turn the internal display on.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
always pleased to see your replies old turkey. i've attached a photo of the LVDS connector and cable end. they both look very healthy.
von
The cable checks out from an appearance standpoint. Still could be an issue with the cable or the connector on the Logic Board itself though.
von
additionally, i've tested every pp3v3_lcdvdd_sw at and after U9000 with no satisfaction
von
@reverendalc connector looks really good. Are you saying you do not have 3.3V on pp3v3_lcdvdd_sw?
von
that is correct. i also added to my original post all of the points i've tested for 3.3v. i'm currently looking at the S5 which feeds U9000, and both pins 2 and 3 carry 3.3v into U9000
von
13 weitere Kommentare anzeigen
Antwort hinzufügen
Ronnoc Nailli wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 120
