Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und seit dem 19. September 2014 auf dem Markt.
4799 Fragen Alle anzeigen
one of the screw hold breaks and I can't turn on the phone
My iphone 6 has a long time problem with the display, some time it turns on when I pressed the power/home button but some time it doesn’t, while the sound and touch id all still works normally, so I suspected that it’s just a loosen cable problem.
So I opened the phone and unplug and replug the cables, but then I broke one of the screw holes when I try to put back everything, and now I can’t turn on my phone. Some searching shows that the screw hole that I broke was responsible for the power supply. How do I fix this?
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Jetzt kaufen
iPhone X Fix Kits
Jetzt kaufen
2 Antworten
Hilfreichste Antwort
If you had a good microscope and excellent microsoldering skills you could rebuild traces that got damaged..it’s not a DIY job, either you’re a pro or you’ll have to find someone do it for you.
War diese Antwort hilfreich?
Punktzahl 1
Kommentare:
I don't have the tools and skills. How much does it cost to fix this in stores?
von
@hoyun Cost of repair may vary with the place you are living..easiest thing is to find someone reputable in your area, but some repair shops offer mail in service too. Good news is many shops offer a no fix no fee service..your issue is quite straightforward repair, thus it won't be too difficult to get a quote.
von
This is known as long screw damage. The traces underneath the logic board have been torn off by the screw, and now the phone is missing vital traces. This can be fixed by a microsolderer, but is a more of an expensive fix.
Punktzahl 0
Antwort hinzufügen
hoyun wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 26
