Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
6s+ Touch ID doesn't work
Last summer, my phone got wet. I took it apart and dried it out but the screen was shot. Ordered a screen from iFixit, moved my home button over and everything has been working great. Fast forward 3 months and I cracked the screen. Ordered another screen from iFixit (and a new battery) and just now replaced them, following the same instructions as before. Yes I moved my home button over. Everything seems to work but no touch id. Home button goes to home screen but I can’t add a fingerprint or otherwise get a response from the touch id sensor. Open the phone and reseated all connectors (home button, display, digitizer, camera) but still no luck. Any ideas. I read it could be a defective screen??
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Just to close this out, iFixit sent a replacement screen and the new one works fine with TouchID. The 1st screen also had some auto-brightness issues and I think that is back to normal also with this replacement.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You either damaged the Home Button or the Link flex that runs under the backlight on the screen is defective/damaged. Try installing the original screen with the Home Button. If it works with the original screen, it means the replacement screen is defective. If it doesn’t work, then you probably damaged the Home Button. Inspect it with magnification. Even the slightest tear can render the TouchID non-functional.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
Ok, I moved the home button back over to the old cracked screen and Touch ID works fine. So I'm guessing this latest screen from iFixit is defective? I checked the cable on the new screen under a magnifying glass and it looks fine. How do I get a replacement?
von
I should also add I did a DFU and reinstalled / recovered the phone. That did not fix Touch ID. Works fine on the old screen. I sent an email to support@ifixit.com. Will see what they say.
von
Please contact iFixit support. We are just volunteers helping people fix their stuff.
von
With water damage, there can always be problems down the road. The first thing you should test is whether it is a problem with the screen. If you still have the broken screen, test and see if the home button works on that. If it doesn’t work on that, then the chances are that the home button is broken. Also inspect the flex cable for any tears.
Bewertung 0
Antwort hinzufügen
Bruce White wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 127
