Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Touch id on iPhone 6s won't work after transferring home button over?
Have a question, Had an iphone 6s where i replaced the screen and transferred over the original touch id, home button as I know you can't use a new one. I've done this many times, but this time the touch id won't work after put back together. It doesn't give any error at all. Just when you try to add new finger print, it acts like you don't have your finger on the home button... No errors. It just won't prompt you to scan your finger and can't get it to work. Any ideas?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
It’s either a bad home button or a bad home button cable by the sounds of it.
von
Thanks. I've replaced the screen twice in this phone, so maybe that's possible. So, there's no way to fix this cause this is still an only apple fix?? It's a backup phone, but I sure would like to get the touch id back. This sucks if apple it still the only one to fix this. Is it weird that there's no error?
von
Einen Kommentar hinzufügen
2 Antworten
@jason_b Well, the fact that your iPhone is giving you no errors is a red flag that either the home button or it's cable is damaged. I think you're going to have to make the sacrifice here and just buy a new home button assembly. If Touch ID still refuses to work after a new home button assembly then we have a bigger problem here, a board level issue.
iPhone 6s Home Button Assembly
iPhone 6s and 6s Plus Home Button Gasket
iPhone 6s Home Button Einheit ersetzen
iPhone 6s Home Button Assembly Bild
Produkt
$14.99
iPhone 6s and 6s Plus Home Button Gasket Bild
Produkt
$5.99
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thank you for the reply!!! But, I thought you can't use a new home button with touch id, and only way to get it to work is to have apple do it to record the ss to the home button? Is this not the case anymore?? We can do it ourselves and get it to work??
von
@jason_b the reason why I said "you're going to have to make the sacrifice here" is exactly that reason there. Nobody other than Apple can "pair" a new home button to an existing device and have Touch ID work. You don't have much of a choice here.
von
Check out this thread for some hints:
Touch ID not working after screen replacement
Bewertung 0
Antwort hinzufügen
Jason wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 364
