Zum Hauptinhalt wechseln
Die Xbox One S ist eine Entwicklung von Microsoft. Sie erschien im August 2016 als Neuauflage der Xbox One.
358 Fragen Alle anzeigen
Bought a banned Xbox One S, what parts can I use?
So I bought this console on ebay and it ended up being console banned, stupid me. What parts of the console are actually banned? I assume it would be the motherboard or network card since those are the main things that identify the console but I could be wrong. Any details would be great:)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Kommentare:
New to this, how do you know if it’s banned?
von
You don't until you bought it unless the seller discloses it :(.
von
I mean, how it shows up on the controller?
von
How do they activate this console ban chip what are you guys thoughts do they activate through your IP of Xbox or what do you think how do they activate this microchip please email me at this email address I would like to hear your answer clintfulk2728@outlook.com
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
eBay has a buyer protection program to guard you against this type of fraud. Why haven’t you used it?
https://www.quora.com/What-is-the-eBay-b...
War diese Antwort hilfreich?
Bewertung 7
Kommentare:
+1, Very good point!
von
Good point from me as well. I will not buy those things unless you DISCLOSE IT and price it accordingly, just in case I can't coax Microsoft to remove it when I get it home to try my luck.
I expect a 50% price break on those.... at the minimum. I am assuming the risk you were the second person to ban it and I'm stuck.
von
Was you able to hear it unbanned my son bought one off merci. And it was banned guy won't refund his money back
von
There’s not much you can do unfortunately. I believe that a device ban affects the motherboard. Apparently (per Microsoft) if your Xbox determines you are trying to circumvent the device ban by doing a factory reset or re-flashing the firmware your Xbox will brick itself.
Your only hope is to attempt to re-flash the firmware and pray that you slip by the tamper detection.
Firmware auf Xbox One S installieren
Onto the parts question, I believe that the only part affected by a device ban is the motherboard. Everything else should be OK.
Bewertung 3
Kommentare:
This will not work as the console identity is baked into the motherboard, probably right into the SoC.
von
@tomchai I miss the days when you could JTAG the ban away :(. It was dirty but it was a way out for someone who can handle it.
They learned their lesson with the 360 since the JTAG hole didn't last too long. The optical drive will work, but it's tied to the banned board.
von
Question… I recently have been banned from cod Cold War. Says my (gamer tag name) has been banned from playing on the cod Cold War servers. Please sign in with another profile to play online. What caused this problem and can it be fixed without losing online achievements n prestige rank?
von
Console banned systems are worth more dead then alive since this (generally) isn’t something Microsoft will reverse. Use it as an offline/local multiplayer only system and treat it as an offline/LAN only system if you’re stuck with it.
Sometimes they do provide exceptions if you buy it not knowing (even if you knew and priced it right, I’d still try that line and be prepared for them to say no), but it’s generally only a one shot deal. If you were buyer #2 of the console in a banned state and someone else already did that, they won’t do it again. Because there are NO GUARANTEES it’ll be done, you should price it to the point you can eat it if it’s dead for good because you’re owner #3.
Back in the 360 days, the CPU identifier was used to block the console and you could use JTAG to get into the system to change it and remove the console ban before they patched the JTAG hack with the 2nd generation dashboard. While the Xbone likely has JTAG presence, it’s likely limited to factory testing today especially since they killed it early on the RROD 360 for what people actually used it for. There will be multiple parts paired to prevent CPU replacement, so you will basically need to replace the board and optical drive to reverse the ban - which may cost as much as a clean one.
Bewertung 2
Note: Before you attempt to take apart/sell your Xbox for parts you should try to contact eBay about the issue as mentioned by @mayer
If the Xbox one is similar to it's predecessor, the Xbox 360, then the only thing that is identifiable (some type of console id) would probably be stored on the NAND. The NAND flash is usually a little chip about 1-2 inches in black on the motherboard that stores the Xbox operating system and other important information. So all in all since the NAND is soldered to the motherboard you could probably salvage everything but the motherboard.
Also I would like to let you know that all this is theoretical and since no one other than Microsoft knows for sure how exactly the console is identified, this is just an educated guess by someone very familiar with RGH/JTAG modded Xbox 360s.
Bewertung 0
Antwort hinzufügen
Matthew Hirmiz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 6
Letzten 7 Tage: 31
Letzten 30 Tage: 130
Insgesamt: 10,217
