Hi @whales75 ,
It seems as though the watch’s battery is failing to hold its’ charge and may need to be replaced.
How old is the watch?
In most locations there is a 12 months manufacturer’s warranty on the watch. If your warranty period is still valid, consult the warranty documentation that came with the watch to find out if it is valid for 12 months and if so follow the directions in the warranty to make a claim for a warranty repair or replacement.
If it is no longer covered by the warranty, here’s a video that shows how to open the watch so that access to the battery is possible and it can be replaced.
It is in Hindi, but the video is self explanatory.
The watch’s waterproof properties will be lost once it has been opened.
You will need to unsolder the old battery wires from the motherboard and to resolder the new battery in, so soldering expertise and tools will be required.
Looking at the video I believe that the battery is a 3.7V LiPo battery with dimensions of 4.0mm x 10mm x 20mm as shown by the code 401020 on the battery in the video.
Here’s a link to suppliers of the battery. It is only shown to give you an idea of the cost of the battery. There are other suppliers online that may suit you better. Just search for 3.7V LiPo battery 401020.
Hopefully this is of some help
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
