Broken wifi antennas - how to solder stripped cables directly?
I have a late 2013 Macbook Pro that’s missing all 3 of the wifi antenna heads/connectors (those tiny copper/R2D2 looking things that you connect to the wireless card on the logic board). I’ve been trying to solder the stripped cables directly to the wifi card but I’ve had little to no success.
I’ve tried stripping the cable to expose the inner/secondary translucent cable . I then stripped that cable to expose maybe 5-6 strands of wire, and then soldered the exposed wires from inside that tube directly to the sockets on the board. After doing this I’m able to connect to my home network but the signal strength is incredibly weak.
I also tried stripping the black plastic back and then soldering the exposed wires that surround the inner cable along with the exposed wires from the inner cable. The results were pretty much the same as above.
Lastly I created a small solder glob in each socket and then soldered the clean cut/non stripped back cable directly to the pin inside the socket but that also did not work.
The wireless antenna cables have a plastic sheath, a copper foil sheath and lots of fragile wiring that surround the inner translucent tube that covers maybe 5-6 more wires.
Anyone know how one would optimally solder the stripped wires directly to the wireless card?
It’s odd because I had better results when I haphazardly used Kapton tape to sloppily affix the stripped cables on top of the sockets.
I’ve searched the forums and have found people with the same question but haven’t found the answer.
Ist dies eine gute Frage?
