Zum Hauptinhalt wechseln
Vierte Generation des iPad 4s mit CDMA. Verfügbar in 16, 32, oder 64 GB Versionen. Modelllnummer A1460.
20 Fragen Alle anzeigen
iPad 4: Black screen, no charging and not powering on!
I have had an iPad 4 for a while now, I decided to start using it again. I had known that the lightning connector stopped working last time I had stopped using it, and I also remember turning it off at 50%.
When I tried powering it on few days ago, it didn’t turn on or charge. So, I decided to replace the lightning connector thinking it had finally died and the battery had probably drained itself. I used the following iFixit guide: iPad 4 CDMA Lightning Buchse Austausch I was actually able to replace the connector fairly easily following the guide (kudos for that!)
But, when I tried to turn the iPad back on, it doesn’t turn on nor charges. I have tried the following things:
  1. Different charging cable.
  2. Different wall connector of the charger (the thing that slides into the iPad charger).
  3. Charging using a computer + iPad’s cables (in case the charger was entirely broken).
None of these result in any response from the iPad, no battery symbol, no apple logo, nothing. Would anyone have any suggestions for me to try to debug this?
Thank you!
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
How long has it been since you had last put it down and stopped using it for a while?
von
Last I powered it down was a month ago. And I distinctly remember turning it off at 50% -ish battery.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It’s definitely not a battery issue if you had stopped using it for only a month. Sounds like a board level issue going on here, probably a bad tristar IC (U2). I would take your phone to a local and reputable microsolderer and see if they can assist you with soldering a new tristar IC onto your iPad’s logic board.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I will try that and report back, thank you!
von
Antwort hinzufügen
Muhammad Osama wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 252
