Zum Hauptinhalt wechseln
Google Pixel ist Googles erstes Flaggschiff-Smartphone, welches am 20. Oktober 2016 veröffentlicht wurde. Das Gerät mit einem 5 Zoll AMOLED Display ist mit 32 GB oder 128 GB Speicher erhältlich und in 3 verschiedenen Farben, blau (Really Blue), schwarz (Quite Black) und silber (Very Silver) verfügbar.
104 Fragen Alle anzeigen
After Battery Replacement, Screen Won't Work
I swapped out the battery on a Pixel recently, I was careful about heating up the adhesive enough and used the plastic pick to sever the adhesive. The screen didn’t crack when removing it. After i got the battery switched out, I put everything back together and turned the phone on. The phone vibrated, indicating that it had turned on, but the screen is black. I was careful not to damage any of the ribbons when pulling it apart. Does anyone know what this might be?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The pixel has a very thin and fragile screen. It's very easy to damage the lcd without being able to see a visible crack. Also you could have knocked off components around the lcd connector. Or it could be a backlight issue. I would use a bright flashlight and shine it on the screen when you think it should be displaying and see if you can see anything. If you can then it's a backlight issue. If you have no backlight and no image then I would start looking at the board for damage. If you cant find any physical damage then I would get a new screen.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Whereabouts on the board would you check?
von
Having the same issue with the Pixel 3. Changed the battery but did break a piece of did the wireless charger and the cable for the finger print scanner. I planned on replacing them eventually but in the mean time my phone won't boot up with the new battery. Won't even tell me it's charging. Having a hard time loading software and idk why.
Bewertung 0
Antwort hinzufügen
Robert Black wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 41
Insgesamt: 3,058
