Zum Hauptinhalt wechseln
Released by Apple on January 16, 1986, the Macintosh Plus is an upgrade to the original Macintosh and the Macintosh 512K.
9 Fragen Alle anzeigen
Can I take case off only and still be safe?
I want to take off the rear of the Macintosh plus case and still be safe? i only want to take the back off and clean it. I dont want to touch any of the components.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yes, taking the cover off and not putting your hands on the side mounted power supply you’ll be OK.
Use a paint brush to scrub the surfaces to loosen the dust and then use a can of can’ed air to blow it away. Don’t touch the yoke as you could alter its alignment and the CRT tube its self is fragile! So don’t bang it!
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
Bobby gunnels wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 419
