Zum Hauptinhalt wechseln
Model A1419 / Ende 2013 / 3,2 und 3,4 GHz Core i5 oder 3,5 GHz Core i7 Prozessor, ID iMac14,2
340 Fragen Alle anzeigen
What do I do with the blade on a failing fusion drive?
I have a 27” late 2013 iMac with a failing (or rather failed) fusion drive. I would like to replace the HDD portion with a 2TB SSD. Do I need to remove the SSD blade? What happens in that case? Can I remove the SSD blade and not replace it? Right now I’m regretting I ever got the fusion drive. Thanks in advance.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
A Fusion Drive is the marriage of a HDD and a SSD.
So at this point has your SSD part is failed or the HDD?
If the SSD failed it would make sense to replace it but I wouldn’t replace it with another small SSD and then redo the Fusion Drive. Instead I would setup standalone dual drive config where you use the SSD as your boot drive and leave your HDD as an independent data drive. While its a bit of work its worth it! iMac Intel 27" EMC 2639 Blade SSD austauschen It will give you the performance you really want. Here’s the SSD you’ll need Blade SSD.
If your HDD died then replacing it with a SSD while doable, can’t be joined to your blade SSD that was part of your Fusion Drive. The Faster PCIe interface of the blade SSD is ideal for your boot drive and holding your cache & paging files setup as independent dual drives.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Tom wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 103
