Zum Hauptinhalt wechseln
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
50 Fragen Alle anzeigen
Why won't my car start?
I have a 2000 Ford Expedition 5.4 liter engine. I currently live in Wisconsin, and the winters have been hard on my battery. Since it started getting cold this year, I’ve been having trouble getting The Beast to start. Up until a week ago, a simple jump would do the trick. Then, last week, I went to start it and it was giving me the usual trying to turn over but slowly sound that indicates that I would need to jump it.
I attached the jumper cables, and there were all indications that a proper connection was made. When I went to start it, though, nothing happened. Turning the key to the ON position has all the dashboard lights come on, the dashboard goes black when I turn the key, and the lights come back on when it returns to the ON position. There is no sound that it is trying to turn over, though.
Our first step was to remove the battery and have it tested. It came back as a bad battery and we’ve bought a new one and installed it. There is still no indication that it is trying to turn over when the key is turned. What should be my next step in diagnosing the problem? As I work through the various components that could be bad and causing it not to start, how will I know if there are multiple components that have gone bad and not just one?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
clean your battery cables that attach to your new battery with a steel wire brush to clean off the corrosion from your old bad battery if you have done this check alternator and then plugs also because your having some cold weather make sure you have more than a couple gallons of gas.good
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Robyn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 66
