Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Green Light turns on in my apple power adaptor. Doesn't charge
So my power adaptor broke 3 months ago so i took another charger and took the magsafe connector and connect it together. it connects and green light turns on but doesn’t charge i tried it with another macbook and it charges.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sadly, you damaged your charging logic inside your system.
Often times when the MagSafe cord fails it can short out the signal line which then damages the charging logic. Review this Apple T/N to make sure you’ve got the correct MagSafe adapter and the cable & connector are both in good shape. I don’t recommend patching the MagSafe cable as you did here Apple Portables: Troubleshooting MagSafe adapters
As to fixing your problem you’ll need to work up the chain starting with replacing the DC-In Board following this guide MacBook Pro (13 Zoll, Ende 2011, Unibody) MagSafe DC-In Board austauschen If that doesn’t change things you’ll need to get someone to fix the logic board.
War diese Antwort hilfreich?
Bewertung 2
6 Kommentare:
Hmmm i just shaved off a bit of plastic from the MagSafe and it works!
The part that connects to the MacBook because it wasn’t getting good connection
Thanks though
von
@zantheproplayz - Thats why I was recommending you replace the DC-In Board as the plastic can soften up from over heating.
von
i completely removed the dc in board plastic..
von
Please get a new one as you don't want a short!
von
too expensive..
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Zander Castillon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 60
