Zum Hauptinhalt wechseln
ThinkPad released in 2011. This version of the T420 is thicker than the T420s and lacks integrated USB 3.0. The T420i uses the same chassis, so most T420 repair guides work interchangeably.
15 Fragen Alle anzeigen
Thinkpad T420, speakers don't work
Thinkpad T420
  • i5-2520
  • iGPU
  • Manjaro linux
Ever since I bought the laptop I’ve had issues with the external speakers. Initially, they would work for a few seconds when messing with the audio controls before they cut out, now they don’t function at all. According to the volume controller, it’s detecting headphones being plugged in when there’s nothing plugged in at all. The external speakers are listed as “unavailable”.
Things I’ve tried
  • Upgrading kernel to 4.18
  • Changing linux distros (I’ve tried Antergos, Manjaro, Ubuntu, Fedora, Mint, and Elementary)
  • Uninstalling and reinstalling audio drivers
  • Cleaning out the headphone jack with a qtip and alcohol
  • Replacing the speakers.
Something I noticed when I first opened it up was that someone probably spilled soda on it as some of it ended up on the motherboard. Really unexpected for a Thinkpad as they have drainage holes through the keyboard. I’m thinking maybe something related to the external speakers was damaged?
Thanks in advance!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi Ahmad. suggest you also inspect the mainboard .
Check for any possible corrosion / damage.. etc.
Would be great if you can provide pictures of it
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hi,
Not all the liquid would have drained out as evidenced by the residue shown in your picture.
Is there audio available at the headphones socket?
If there is audio at the headphones socket I suggest that you try and gently clean all of the residue off using Isopropyl Alcohol 99%+ and a Q-Tip, especially where it covers the circuit board as shown in the picture.
As always when working on electronics (except when testing) disconnect the power from the systemboard to prevent any possible problems from occurring due to “accidents”. The Power button is not a power isolating button and power is still available at various points on the systemboard. Also be careful not to damage the board or any components or tracks covered by the residue
It may be that the residue is conductive and is the cause of the problem.
Normally what happens is that when headphones are plugged in, an internal contact in the socket is operated and depending on the type of socket, it either breaks the audio connection to the internal speakers and switches the audio to the headphones or it sends a signal to the BIOS/OS which software switches the audio away from the internal speakers onto the headphones. So given that there is an indication that there are headphones plugged in you are probably right in suspecting that the BIOS "thinks" that there is something plugged into the headphones, when nothing actually is.
If there is no audio available at the headphones socket perhaps the socket (audio board?) is faulty and your cleaning attempt didn’t resolve the problem.
On p.140 of the service manual it shows that there is a audio sub board (part #9 shown on p.134). When searching online using the part number only (04W1623) the part is available. (It seems to be very expensive for just an audio card)
War diese Antwort hilfreich?
Bewertung 3
Thinkpad T420 speakers are known to be defective and do not work properly. There are several reasons why this might be the case. One potential issue is that the speakers might be defective. This can lead to them not working properly, or even not being able to produce sound at all.
Another potential issue is that the audio input on the laptop might not be working properly. This could be due to a damaged or missing audio jack, or it could be due to a problem with the audio circuitry on the laptop itself.
If the audio jack is damaged, it might be difficult or impossible to get it repaired. If the audio circuitry on the laptop is damaged, it might be difficult or impossible to get it replaced. In either case, the speakers might not work properly as a result.
Fix Sound Issue Of Lenovo laptop
If your Thinkpad T420 speakers do not work, there are a few things you can do to try and fix the issue.
  • First, make sure that the speakers are plugged into the computer and that the audio drivers are up to date.
  • If the speakers are plugged in, make sure that they are turned on and that the audio drivers are installed.
  • Next, try restarting the computer. If the speakers still do not work, you may need to replace the speakers.
  • You can follow the steps Lenovo Thinkpad no audio to fix the problem
Bewertung 3
If lenovo laptop internal speakers are not working but headphone works fine. here are the way to get it fixed.
  1. first of all, you need to enable the audio on your computer.
  2. Update the sound driver.
  3. Reinstall the sound software in your computer.
  4. Reset the computer, if necessory.
Once you make these changes, the audio will start working fine. in case, if you are dealing with some other issues, please feel free to visit: lenovo laptop sound not working.
Bewertung 0
Antwort hinzufügen
Ahmed Khalil wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 22
Insgesamt: 884
