MacBook Pro not turning on. (No chime, no fans)
I recently applied fresh thermal paste to the CPU and GPU and also installed an 970 EVO SSD to my Macbook Pro (A1398). It worked perfectly for two days and I was switching back and forth between the new SSD and the old SSD to backup and restore certain data.
And today it suddenly won't turn on (Merry Christmas!). When I try to turn it on, there is no chime, no backlight, no fans noise, and no illumination on keyboard/caps lock. When I plug the Magsafe charger in, charging indicator lights up green. And when I plug in an external HDD through the USB port and attempt to turn Macbook on, the external HDD makes spinning sound as if it was plugged in to a working computer. The sound continues until I force shut down the Macbook. However, a strange thing I noticed was if I turned the Macbook on with external HDD but without the charger plugged in, the external HDD makes those spinning sound for only 5 secs and then stops as Macbook apparently shuts itself off.
I tried the ‘spontaneous boot' that was suggested: Macbook was completely unresponsive. However I do not believe the logic board is fried as I can SMC reset and see the charging light go from amber to green. Also tried power cycles with original SSD, with new SSD and without any SSD: no luck. Tried powering it on with batteries attached/detached, tried with charger attached/detached and possible combinations of them: nothing.
I should also note that I'm not completely ruling out the possibility of liquid damage as I spilled a teaspoon amount of Isoprapanol to the logic board while cleaning off the old thermal paste. However I cleaned the spill immediately and Macbook worked perfectly fine for two days after that.
Does anyone have any idea what could be the issue here? Or at least what issues can I rule out given the above observations? Would really appreciate any sort of feedback or advice from this forum.
Thanks!
Ist dies eine gute Frage?
