Zum Hauptinhalt wechseln
Das Samsung Galaxy Note 4 ist ein Smartphone, das im Oktober 2014 heraus kam. Die Modellnummer des Galaxy Note 4 ist bei der amerikanischen Variante eine der folgenden: SM-N910, SM-N910A, SM-N910T, SM-N910V, oder SM-N910R4.
256 Fragen Alle anzeigen
Phone keeps vibrating and won't turn on
Hello
My phone switched itself off and is now vibrating twice and keeps flashing the samsung sign.
I downloaded an app off Playstore yesterday and everything seemed okay. But now it is not working properly.
I tried to do a reset but it is still not working.
Help please
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
HPhone keeps vibrating and won't turn on
von
My samsung j1ace suddenly tripped off. When I tried turning on it started vibrating and the screen was blank. Pls what can I do?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
May I know the app you downloaded?
This ‘app’ may of downloaded malware to your device and caused the phone to keep shutting itself off.
Otherwise, try the following steps;
Step 1. Open the back cover of your Note 4, remove the battery and wait a couple seconds, then insert it again.
Step 2. Hold the volume up key, power button and the home button simultaneously. When the ‘Recovery Booting…’ text, release these buttons.
Step 3. Select the cache option and press reboot. If this doesn’t work, repeat Step 2, press the cache option, and select format device. (Note! Formatting your device will wipe your device clear of all files.)
Hope this helped!
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Hi I downloaded Wordscape.
I have tried step 1 and step 2.
I have attempted to try step 3 and it said Recovery Booting, I released the buttons and it said installing system update and keeps restarting again.
von
Oh ok, instead of me explaining it and getting you to understand, please watch this helpful video on YouTube: https://www.youtube.com/watch?v=KCocwC50....
Edit: Also, try just letting it keep restarting when it's installing system update, after a preset amount of time it will stop restarting and give you the normal recovery options.
Hope this helps.
von
Thankyou. I will have a look at this video :D Hopefully, it will help.
von
Antwort hinzufügen
alishasamms305 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 40
Insgesamt: 8,861
