Zum Hauptinhalt wechseln
Reparatur und Unterstützung für den zur PS3 gehörenden Kontroller. Er kam 2008 heraus, besitzt einen Lithium-Ionen Akku und eine Sechsachsensteuerung. Der Kontroller (CECHZC2) ist leicht zu reparieren.
Analog stick replacement CECHZC2E
I disassembled my PS3 Dualshock 3 controller, because the left analog stick has broken, and didn’t move back to the middle position. (Looks like the spring not functioning)
I desoldered the broken analog, and ordered one with the same pin layout (3pin version).
When the new part arrived, I had realized, while the number of the pins are the same, their position are different, so I cannot solder it to the PCB.
I searched on the web, but I didn’t find that type of analog stick, what I exactly need. (Just the 3 and 4 pin version, which are not what I need)
Do you have any idea or tip, from where can I order this kind of analog stick?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I am facing same problem, still couldnt find similar looking analog stick. All looks smaller like djjano1 posted and if they dont look smaller the micro switch looks like 6mm version instead 4.3mm like on this analog. I have same CECHZC2E B1 dualshock3.
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
djjano1 there are 3 revisions of the Dualshock 3 CECHZC2E, CECHZC2E A1 and CECHZC2E B1. Your analog stick looks actually more like a PS4 replacement
Check on places like this for a better replacement
War diese Antwort hilfreich?
Bewertung 3
Seems you have a new version of the controller, made for release with the PS3 Slim. Try looking for those parts. I couldn’t find anything quickly, but you can always try it yourself.
Bewertung 1
Same problem Here.. no fix yet…
Bewertung 0
Apparently this version is really successful fake controller, hence the differences. I used Xbox 360/PS2 analog and replaced the push button of correct size (way smaller). Had to create holes in plastic for button legs but it works. Cost was under 2$, button were actually more expensive (1$) as I had to order at least 10.
My original idea was to use inside of new PS2 analog and replace the original one, but dont remember why it was not feasible.
Bewertung 0
I'f this model was fake?? Why did I get it in the box with the ps3 phat and the ps3 super slim sealed from the sony factory…
Bewertung 0
2 Kommentare:
SCP toolkit refers to it as fake, on motherboard sticker is not Sony but something else (forgot what exactly and too lazy to open the controller). I found it in past on some site in search of these weird analogs that its supposed to be really well done fake. That would explain why there isnt single analog for this DS3. Believe me or not, up to you. Its possible to fix it and it works as new, thats what matters to me.
If you post PCB from both sides, I might be able to find the site which claims that its fake.
Edit:
Found it is Asuka board
https://www.psdevwiki.com/ps3/DualShock_...
von
Antwort hinzufügen
djjano1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 33
Letzte 30 Tage: 154
Insgesamt: 5,301
