Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1203 Fragen Alle anzeigen
MacBook Late 2006 boots to white screen, but works on external monitor
I recently swapped the display in my Macbook Late 2006. It was cracked and I found a cheap working display on eBay . The Macbook boots okay but the display remains white. I connected an external monitor and the Macbook works fine with that.
Do you think it’s a faulty display?
Or is it possible I have connected the display cables incorrectly?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sounds like you got the wrong display assembly. While they look the same they are not the same!
MacBook 13.3" Core 2 Duo Display Assembly Bild
Produkt
$299.99
MacBook 13.3" Santa Rosa/Penryn Display Assembly Bild
Produkt
$299.99
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Ok thanks. I’ll have a look.
Is there a way to check the display part number from System Profiler or using an app?
von
Plug in your systems S/N into here EveryMac - Lookup it will tell you the exact model you have as they both look the same.
Basically, the Intel graphics services (Intel GMA X3100 & Intel GMA X3100) is what defines which display is needed. As the signaling is different enough that each needs a unique display assembly.
von
Antwort hinzufügen
Matt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 48
