Zum Hauptinhalt wechseln
Das Flaggschiff-Smartphone von Motorola, das im Juli 2015 angekündigt wurde. Es ist mit einer 21 MP Kamera ausgestattet sowie einem 5,7" IPS TFT LCD Display mit einer 1440 x 2560 Auflösung, was es zu Quad HD macht. Modellnummern: XT1570, XT1579, XT1575 und XT1578.
After battery replacement, won't turn on
I replaced the battery in my Moto X and now it shows charging the battery but won't turn on.
I plug it into a charger and it comes up showing the charging screen. But doesn't turn on. Any idea why?
It is almost like the power switch isn't working even though I didn't touch the switches.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
the phones I have done in the past have normally needed to be charged for a bit before they would fire up. how long have you charged the new battery.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
At least 30 minutes. With the phones turbo charger, that should have given it at least 50% if it was completely dead.
von
I am having same problem and battery is charged to 100%. Cant tell if the one ribbon is seated correctly.
Bewertung 0
Had the same issue, had to tear the phone open three times. make sure the all of the cables are seated . The problem in mine came from the power/volume ribbon being attached but not being fully inserted and touching the battery. Even fully inserted it would not power on unless it was touching the battery, also check the flash connection at the motherboard.
Bewertung 0
Antwort hinzufügen
Shawn Baumgarner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 1,073
