Why is my iPhone not charging?
I plugged it in to charge one day and it just stopped charging. The battery ran down until it died completely.Someone took out the battery and charged it. Then, the phone worked normally until it died again.
Ist dies eine gute Frage?
10 Kommentare
Does your phone show the charging icon when it is plugged into an AC power source?
von Scott Head
It sync with iTunes.Once power in the battery it works normal.I was told that it is the power IC that cause it not to charge.
von Moris
Hello,
I have the same problem with an iPhone 4, the charging dock seemed to be defective, so I replaced it, but it didn't change anything; the phone dosent charge... I tried to change the battery, same thing here...
If someone has a solution, it would be very nice to share it with us !
von Thomas
I was charging my phone and I feel off the couch and it stop working. So when I went to bed it was at 32% then when I woke up that morning it was at 50% I unplugged it and I jumped back down to 32% How can I fix it?
von Izzy
I'm facing charging problem with my iPhone 4S.
When I plugin the charger, it doesn't start the charging right away. It takes hours of time to fill in.
And there are cases when it doesn't even start charging.
I cleaned the charging port with an old tooth brush and tried all the tips, which dint help me.
I believe there might be some problem with the updated iOS for iPhone 4S.
Can anyone help me to fix this ?
von rakesh karnam
5 weitere Kommentare anzeigen
