Zum Hauptinhalt wechseln
Released in 2012, the Asus N76VZ is a 17-inch laptop with a screen resolution of 1600x900 pixels or 1920x1080 pixels. It has a 3rd-generation Intel Core i7 processor and an Nvidia graphics card inside.
6 Fragen Alle anzeigen
Why can't remove battery
Hello
I am trying to remove battery on Notebook Asus N76V, but I think it have problem with the slider lock because he is on the wrong position and now it is very hard to remove it, I tried a little force to remove it but I wasn’t able to do it… I searched many solution but I didn’t found the solution.
Edit: it is Asus N76VJ but I think it’s the same way to remove battery.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It’s likely that the slider to unlock the battery is broken. First try sliding it to the unlocked position and force the battery out. There isn’t much you can do other than replacing the bottom case. I’ve found though that a lot of times if I force it out, it will come out with little damage.
War diese Antwort hilfreich?
Bewertung 3
with flat head screwdriver,
start to lift battery pack from back ( furthest away from battery open slider )
start to lever from right or left ,,, lever from either corner
This worked for me and i did no damage to mechanism
operate lever and apply some silicon spray
Bewertung 1
1 Kommentar:
This was actually helpful!
I used a plastic pick and started wiggling and sliding.
I spent more than 30 minutes trying before seeing this tip, and I was so happy that I didn't break anything lol
Thanks
von
Antwort hinzufügen
Mickael Gomes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 878
