Zum Hauptinhalt wechseln
{A1706 / EMC 3071}—Veröffentlicht im Juni 2017. Dieses 13" Macbook Pro ist mit Kaby Lake Prozessoren bis zu 3,5 GHz Core i7 mit Turbo Boot bis zu 4,0 GHz ausgestattet.
276 Fragen Alle anzeigen
MacBook doesn't boot after Mojave Update
Hi,
After updating to mojave, a friends macbook doesn’t boot anymore. First it did but the touch bar wasn’t working. After that, it didn’t boot anymore. The backlight is turning on but no feedback from the macbook, no chime, no beep, no apple logo.
I tried a lot of short cuts already (NVRAM and SMC reset) but since there is no feedback at all, it seems like the commands are not getting executed at all.
Currently I just let it run with the backlight on so the battery gets discharged.
I could open it and disconnect the battery but I don’t neccessarily want to remove the tapes on the battery cables if possible.
Anyone here experienced this or has a suggestion? The next genius bar is 2 hours away and I don’t have a car.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Ouch! Even if you open it up there is really isn’t much you can do. Then if you do open it up you might give Apple an out to not fix it under warranty depending on what country you are in and if your friend got AppleCare+ service contract.
I guess you’ll need to find someone to give you a lift to the Apple Store. Sorry ;-{
War diese Antwort hilfreich?
Bewertung 2
7 Kommentare:
Unfortunately, there is no warranty left and no AppleCare+ plan was purchased :(
I still hope that a discharged/disconnected battery can bring the cure…
von
@gemba - Where are you located? Country and major city.
von
Sweden, next bigger city would be Gothenburg.
von
You do realize its still covered under Swedish consumer warranty law (three years). Best to make your way to Apple for a FREE repair!! Guarantees and returns – Sweden
von
I think it was purchased in Germany since it has a German keyboard. And as far as I know under German warranty law, in the second year, you have to prove that the issue/problem was there when you purchased it. Thank you for your effort though!
The battery just died and I charged it again -> same issue :(
I guess there is no other way than bringing it to a genius bar appointment, right?
von
2 weitere Kommentare anzeigen
I had the same problem
After an update the macbook pro touchbar was dead.
Now I also don’t live near an Apple store (about 7.000km away!), but speaking on the phone with them they said that is not possible that is because of their update. now there is another person having the exact same issue, and I am sure there are more.
I am sure we can find more people with the same problem
Andrea
Bewertung 0
1 Kommentar:
@andreaderosa - Christian's has a different issue than you.
Give this a try: How to Manually Refresh Touch Bar on MacBook Pro
von
Antwort hinzufügen
Christian Oehne wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 165
