I can only add my experience here, but I thought it worthwhile to share.
All the 'B+numbers' glues are indeed polymer glues made and produced in China, from a Chinese company named Zhanlida that came up in 2018. Not exactly copycats, as there are no others of the exact same type produced, but they make it after the composition of E6000, which is a product and trademark name of Eclectic USA. Just like generic drugs, but without the oversight that comes with having to pass a standard.
https://www.zhanlidaadhesive.com/which-t...
http://eclecticproducts.com/downloads/td...
All of them, including E6000, are decidedly NOT of the superglue kind. Once cured they remain elastic and somewhat resilient, despite strong adherence. They take some time to cure after application, can be repositioned for up to 5 minutes and the parts need to be held together (although not clamped tight, for that may cause most of the glue to be squished out) until cured -- in my experience, 12-24 hours is best.
I have used mostly E6000, for over two decades. I found it especially good on acrylic and similar plastics, glass, stone, and it will stick together wood, fabric and leather without problems. Not for great weights, though.
The advantage is that the excess can be cleared off with an Exacto knife or razor blade... and if you have to pull the thing apart afterwards, even years in my experience, an utility knife is all you need, so long as the glued surface is straight enough for it to fit (I have taken off stones from settings, but it's a gamble).
I have used some of the B+ line for curiosity in the last couple years. I find them not so bad, but in my experience E6000 is better. And the price is not greatly different. You can find both varieties at Home Depot or Walmart.
Hope this helps!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
I'd really like some more input on this one as I still don't know what to use or when, or if theses are all the same or if I just stick good old Emers glue on everything.
von mayer
