Zum Hauptinhalt wechseln
iPad Air Wi-Fi und Mobilversion, Modellnummer A1475. Verfügbar in Space Gray oder Silber, Speicheroptionen 16/32/64/128 GB.
125 Fragen Alle anzeigen
Cellular network connection issues in ipad under OSX (12.1.3)
I had raised this question a week back and may be it was too confusing to attract any notice and draw any answer.  Sorry about that.
The issue is related to ipad air 5 (wifi+lte) with latest osx (12.1.3). I am trying to connect it to the Jio net in India with a Jio 4G SIM card using a “Jio 4GVoice” calling app. I try the following.
·      SIM card is put in the system
·      WIFI is selected (through a personal network)
·      Mobile Data is switched “ON”  (in Settings)
·      Network selection is set to “Automatic
·      LTE is enabled (in Mobile Data options)
Under Settings>General>About  the Carrier is shown as “Jio 35.0 and Network is shown as “Not Available”. Selecting network manually (to Jio4G) has same effect.
·      Resetting network and rebooting repeatedly or switching Airplane mode On and Off has no effect.
·      Change to a different network (AirTel India) has the same effect > Network not available.
·      Followed all steps as suggested in
https://www.igeeksblog.com/4g-3g-lte-not...
From various discussions it appears the network data needs to be updated. For Jio it should be Jio 35.1 instead of Jio 35.0. It probably could be set under Profiles & Accounts. Somewhere it is also suggested to change the configuration. But I don’t know how. Thanks.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
From what I see, I’m not even sure if the LTE functionality is working in the first place, or if it is even compatible.
Is it a Model 1475 or 1476?
Do you have any example of working model 1475 or 1476 on given networks?
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
The model is "a1475". Unfortunately, I don't have a working model to compare. May be I will try to look for one. But iPhone models running OSX 12.1 have similar problems. However, Clicking on the "Carrier" tab under Settings>General>About
updates the network carrier to Jio 35.1 and the problem is solved. In some cases waiting for the carrier to update also works. Please see the link I had given. Many people report that.
von
Antwort hinzufügen
Durga Mahapatra wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 64
