Zum Hauptinhalt wechseln
Model CUH-ZCT1. Dieser Sechsachsen-Controller mit dem 3,7 V Lithium Akku, den Sony im November 2013 auf den Markt brachte, ist leicht zu reparieren. (BEACHTE: Die Teardown-Anleitung ist NICHT für dieses Modell)
386 Fragen Alle anzeigen
Faulty analog sticks - only up and down axes on left and right
Hello
Im trying to repair controler (magma red version) with faulty analog sticks.
Only vertical axes are dysfunctional -they go both “up“.
I connected them to PC and its shows me this in neutral position:
Also if i put some pressure to right stick - like almost hitting R3 it then stabilizes like it should work in neutral position - and funny thing - pushing it also affects the
What i tried to do is clean potentiometer “disks” on both those axes. It didn’t changed anything.
However sticks look like they are covered in some… slime or oil.
I recorded it and sent it to youtube.
https://www.youtube.com/watch?v=Wokj0D1p...
If you look closely you can see its almost glowing.
So my question is - is it some kind of oil or lubricant put on purpose or can it be soda someone spilled out?
I opened about 3 or 4 dualshocks and have never seen something like that - however i havent yet seen sticks with black plastic parts - only those “white and green type”
I also found something like this near charging port and i was able to scracth it from PCB (no harm done).
So if it is some soda how can i clean it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I had something similar happen recently to one of my controllers. I did basically the same thing you did only I de-soldered the whole stick to clean the potentiometers, but did not get any improvement. The only thing which worked for me was to de-solder the whole analog stick assembly and solder in a new one.
As a side not I also saw a goo on my sticks, but after replacing the stick and getting a better look at the stuff I just decided it was some kind of lubricant from the factory.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
win.fatal.error wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 171
