Zum Hauptinhalt wechseln
The first generation Honda CRV, produced from 1995 to 2001.
20 Fragen Alle anzeigen
Starter doesn't engage. Makes no attempt to crank
It works sometimes. But most times when you turn the key on the lights and everything turns on but the stater win’t crank. Battery has been replaced. Starter has been replaced. Still same problem.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Use a multimeter to check continuity of the battery cable from the battery to the solenoid . Have someone else move it while you are checking. It may be partially corroded on the inside.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Both battery cables have been changed no difference. Starter also has been replaced. When you turn the key in lights and everything turn on. Sometimes it will crank and start but most times it doesn't do anything. No clicking no lights dimming.
von
Sounds like an ignition switch if the starter relay is not clicking in the start position of the switch. When you first turn on the ignition switch but not yet cranking, do you hear the fuel pump PRIME then turn off? The fuel pump should also turn on while cranking, do you notice this also?
von
Antwort hinzufügen
metzgerjeffery wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 446
