Zum Hauptinhalt wechseln
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
25 Fragen Alle anzeigen
I keep getting oil in my spark plugs
I keep getting oil in my spark plugs and I’ve already replaced the valve cover and gasket. How can I fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @noremac168 ,
Is there blue smoke coming from the exhaust?
This link gives some of the reasons for oil in the spark plug well. (scroll down to the Common reasons for this to happen: paragraph)
War diese Antwort hilfreich?
Bewertung 2
6 Kommentare:
No it’s white but it smells like burning oil
von
Hi @noremac168 ,
White is also not good. It usually indicates coolant getting into the cylinders/exhaust manifold.
Are you also losing coolant?
Does the oil on the dipstick have a milky look or even bubbles?
von
I’m not losing coolant just oil
von
Hi @noremac168 ,
Are all the plugs covered in oil or only one or a couple?
If not all then it may pay to get a compression test done on the cylinders to check if the leak may be through the rings or the valve guides
von
After I replaced the valve cover it’s been just one
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Cameron Cranford wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 10
Letzten 30 Tage: 37
Insgesamt: 2,627
