Phone wont power up
I dropped my phone and it was fine, until the next morning it wouldn't power up. But when I plug it in the blue indication light comes on. What could be wrong with my phone
Ist dies eine gute Frage?
Try booting to recovery:
If you can get in recovery, I would try wiping your cache partition (you use the volume buttons to navigate and power button to select). If it still doesn’t boot after wiping the cache, you might need to factory reset the phone (which you can also do in recovery).
War diese Antwort hilfreich?
I've tried this more a few times to no avail, I thank u for your help tho
If the power button is broken/unresponsive then obviously using it to try to reboot the phone is pointless. I also have this same issue. I can’t find any info anywhere about fixing or replacing the power button, DIY.
Either try to get it fixed somewhere or see how much Motorola charges. Otherwise, get another phone (NOT a Motorola!). I had my phone less than 6 months when it crashed and the power button hasn’t worked since. Motorola only has a 6 month warranty for this phone - now I know why.
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 13
Insgesamt: 649
