Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
Screen won't close tight after display replacement
I replaced new display for iPhone 7 by LCD Screen and Digitizer Full Assembly Fix Kit and I have no problem during repairing steps where I applied new display adhesive.
Now I have problem when I close device that is a gap between the display and rear case, exactly on bottom right corne and on half bottom of right side.
What do yo suggest me ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
I found out problem! It’s problem with new display, I tried to assembly again the old display and It closes tight.
There is IC cent to display flat and It’s not aligned, infact bump into metal shield of rear case.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Hi
Perhaps your phone frame is bent, because of this skew the screen does not sit tight to the frame
Bewertung 1
I have the same problem for mine, and I think it might be that the battery bracket may be pushing up on the screen. My battery bracket was popping up on one side while the other was screwed down and I had trouble screwing both of the the tiny screws in without one popping out. This causes the entire battery bracket to sit at and upward angle and apply pressure on to my screen. This may not be your exact problem but it is worth a try to see if that could be it.
Bewertung 0
it will be the small rectangular heatshield on the back of the new screen not alignet correctly, there is a recess on the loud speaker it has to sit in.
Bewertung 0
1 Kommentar:
strange thing is the old lcd sits down correctly, what do you think? It's design flaw?
von
I tried everything on mine and it ended up being that the back was slightly bent. I bent it back into shape gently and resolved the issue.
Bewertung 0
1 Kommentar:
omg i had the exact problem and thank you i wouldnt think the frame would be bent now i know the actual reason
von
Antwort hinzufügen
Riccardo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 2,077
