Zum Hauptinhalt wechseln
Die Nintendo Wii Spielekonsole erschien Ende 2006 und wurde bis 2011 produziert.
286 Fragen Alle anzeigen
Why will my wii read a game disc, but a wii u will?
I recently bought a used copy of smash bros brawl, when I put it in my wii, it says it cannot read it. All my other games work just fine and the brawl disc was in good condition I tried putting the disc in my brother’s wii u, and it worked! I have been hacking the wii using the sd card, so maybe thats the problem? No idea, please help.
Ist dies eine gute Frage?
Bewertung 2
3 Kommentare
Are you sure it's not a Wii U game?
von
yes, it is smash bros brawl which is only on the wii
von
It could have been the fact that you attempted to hack it, and caused the disc reader and other programs to misbehave.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
This is a pretty common issue on older Wiis with dual layer disc games. Not many Wii games use dual layer discs but Super Smash Bros. Brawl does, so it’s likely that your other games you’ve tested aren’t, and that’s why they work but this one doesn’t.
Here’s a list of Wii games that use a dual layer disc. If you own any of these games you could try testing them as well.
This issue does mean your DVD drive/laser will need to be either cleaned or replaced. If you’re feeling up for it, you could follow this guide to remove the laser, and clean it with a method like this (see step 3). Otherwise, if the cleaning doesn’t work, the laser will need to be replaced completely using the aforementioned guide and a new laser. However, the easier method would be to replace the entire drive.
Nintendo Wii DVD Drive Lens Bild
Produkt
$34.99
Nintendo Wii Linse am DVD Laufwerk Bild
Anleitung
Nintendo Wii Linse am DVD Laufwerk austauschen
Schwierigkeitsgrad:
Mittel
1 - 2 hours
Nintendo Wii DVD Laufwerk Bild
Anleitung
Nintendo Wii DVD Laufwerk austauschen
Schwierigkeitsgrad:
Mittel
1 - 2 hours
Philips DVP642 Bild
Anleitung
Laser Lens Cleaning
Schwierigkeitsgrad:
Leicht
10 minutes
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Randomperson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 875
