Zum Hauptinhalt wechseln
Reparaturanleitungen für Kühlgeräte, wie Kühlschränke und Gefrierschränke
1645 Fragen Alle anzeigen
Why is my fridge making a dripping noise?
In the back of my refrigerator I can hear a dripping noise. I pulled my fridge out and saw it was coming from a clear/white plastic pipe and dripping into the bottom of the metal part of the fridge. Don’t think that it’s the drip pan because it is attached to the frame.
Below are some pictures of what I’m talking about
https://imgur.com/a/OyEFlEj
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
I think we need @ladytech on this one. Please give us the model number.
von
i hate the drip - argh!!!!! Why me - whyyyyyyy!!! make it stop - the insanity!!!
von
I also have the problem of hearinh that drip drip sound and the fridge is not making ice but the light is on and engine is working
von
@Sbongile Lorraine The dripping noise is normal. 60 years ago you wouldn’t have had to listen to the drip drip drip because you’d be defrosting your freezer, full of ice and frost, by hand. It wasn’t a fun job. Messy and time consuming. Now refrigerators defrost themselves. The dripping is the water running into the pan down below. Check your door gaskets for any tear. Make sure it’s sealing when closed. The more tge door is opened, the more frost will build up, meaning more dripping.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
That J shaped plastic tube is the drain tube. The pan below it that it drips into IS the drain pan. The pan isn’t designed to be removed. The water it collects will evaporate from the heat from the compressor and the condenser fan blowing air across it helps cool the compressor. This is the design used most often. The j shape of the tube is designed as a P trap. The bottom of the J will always hold water. This water keeps warm air and dust from going up the tube. It’s a brilliant design. Everything is as it should be. I hope this helps.
War diese Antwort hilfreich?
Bewertung 4
yeah but…. drip drip drip drip - insanity - drip drip drip rage drip drip drip - really? add a hose to allow it to flow and avoid the noise.
Bewertung 1
3 Kommentare:
I was hoping to get an answer, too....it drives me bonkers --it's almost incessant.
I was sure something had to be leaking!
von
Yes, adding a hose that fits tightly should remove the dripping noise
von
Add a hose to what to stop the dripping noise
von
Antwort hinzufügen
Jacob Rollin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 59
Letzte 30 Tage: 248
Insgesamt: 33,325
